I keep getting a message saying the port i'm set for is not available.
What am I doing.
By: Support,
Posted on: Feb 24 2011 at 12:11:12 AM
If you're getting the message that the port is not available - are you sure that the port is available ?
easyDnc tries to open the port but if the port doesn't exist or if it's in use by some other program then easyDnc has to display the message that the port is not available.
Go to
www.comdiag.com
Download and install comdiag. The free version of that tool doesn't check everything but it will search yoyr computer for available ports and confirm what is and what is not available.
Perhaps the port is available but just not with the com port number that you expect. comdiag will tell you what ports are available in your computer
