Topic: port scan
By: coachjcsmilesPosted on: Nov 14 2007 at 06:53:25 PM
:!: I used the port scan feature to set my settings and now I get a buffer overflow alarm at the control.
Im using a Fanuc 15-m controll and would love to learn the correct settngs in pn and in controller.
THANKS
cjc
By: SupportPosted on: Nov 15 2007 at 12:25:10 PM
Check the flow control setting. Port Scan may have changed it to RTS/CTS.
During drip feeding you probably need to set this to XonXoff.
Strange thing about the fanuc is that when sending data to the computer it enables RTS/CTS which is detected by portscan but then when drip feeding the fanuc prefers XonXoff and ignores RTS/CTS.
Check the setting in easyDnc and switch it to XonXoff.
See my reply to your other post about block delay, baud rates etc.
Also do a search on the forum about "FIFO".
