I set-up 2 machines with easydnc with no problems. On the third machine, when I clicked on the recieve icon, it started to recieve the information below without any prompt from the machine. It just started automatically. Any suggestions to the cause of this?
Some machines, for example Fadal, can dump the current program out of the serial port as soon as RTS/CTS goes high - this means as soon as you connect the cable or start up the DNC software you might receive some data. Because the data is junk you probably don`t have the DNC software set to the correct baud rate.
