I use Easy DNC version 4.1 drip feed work perpectly with any big program or fast feed rate. Only problem is at the end I have to wait a long time ( depend how large program )for software refresh program back to begining. I wonder if I did not do a configuration right. Please help
By: Support,
Posted on: Apr 24 2010 at 05:46:43 PM
Do you mean that you're using the Auto Repeat DNC capability so that easyDnc restarts the same job without you needing to go back to the computer ?
If I've understood that correctly then there should only be a 5 second delay - easyDnc waits 5 seconds and then it waits for a start signal from the CNC (Press the cycle start button on the CNC)
The only setup option is to enabled or disable Auto Repeat. There is no way to change that 5 seconds.
How long do you have to wait ?
If you think I've misunderstood what you mean then please email me
