Topic: Remo mode on older Fanuc
By: GuestPosted on: Jul 18 2018 at 09:49:59 AM
How do I remote request a program at a machine if machine doesn't allow me to type brackets "()"? Machine is a '91 takisawa with Fanuc o-t control with limited keyboard characters.
By: SupportPosted on: Jul 19 2018 at 02:05:51 AM
The UserGuide suggests using the following syntax.
O9999
(1234)
Machines that can't use (brackets) should also be able able to use.
O9999
P1234
So, prefix the fanuc Program number with the letter 'P'
Anyone else reading this that hasn't seen or used the 'remo' mode before can see this info:
Setting up Remo DNC
