Topic: RemoDNC saving files beginning with O
By: PurbeckPlodderPosted on: Jun 18 2013 at 10:53:30 AM
We are testing the REMODNC (very impressed so far) and we have an issue with saving files in REMO mode. We have two machines connected:
1. MORI SEIKI with a Fanuc Series 15 - M
2. Doosan ACE VC500 Fanuc Series 18i -MB
REMO is set up exactly the same on both machines:
Mode FANUC
Remo Reqst Tag 9999
Extension NC
Incoming Program Names AlphaNumeric
Yet the files sent from the MORI SEIKI will save as O1234.NC whereas the files saved from the VC500 save as 1234.NC.
We would like to keep the O1234.nc as that is what everyone is used to. Is there a setting that will enable the O to be reconised?
Many thanks
By: SupportPosted on: Jun 19 2013 at 07:36:10 PM
That is because the fanuc is configured to send the : instead of O.
You need to make the change in the fanuc's parameters.
By: PurbeckPlodderPosted on: Jun 20 2013 at 08:50:44 AM
Could you tell me which parameters?
By: PurbeckPlodderPosted on: Jun 21 2013 at 11:51:58 AM
Found it:
Parameter 3201 bit 3
PUO When address O of a program number is output in ISO code:
0: ":" is output
1: "O" is output
