Topic:   RENAME Issue
By: GuestPosted on: Mar 27 2025 at 01:12:13 PM
I just upgraded with new PC's in the shop for Win 11. I reinstalled the REMO version (5.0.55) that I had on my stick from the last time I had to perform upgrades for Win 10. I had all my REMO machine settings documented so when REMO was installed I was able to quickly get my machines communicating. One of my operators made me aware of an issue today. It seems the RENAME is either being ignored or if a file is being downloaded from the machine to the PC and there is already a file of the same name in the PC it will save the file using the O number as its name and not overwrite the existing file. I checked the RENAME and naming criteria had not been altered by the operator. Everything in the program looks as though it should work properly. Also no machine settings have been altered. Either I missed a setting on REMO or I have to change something due to the PC change. Before I started digging into this I wanted to check and see if you have heard of this before and have an idea on what I need to change. Thanks, Gunner.
By: GuestPosted on: Mar 27 2025 at 01:18:25 PM
Just FYI, I checked a couple other machines and noticed the same issue. For some reason if a file with the same name as the rename already exists in the folder it will not overwrite the old file and will revert to the O number as its naming criteria. This will definitely cause problems if I can't find a fix. Thanks, Gunner
Topic:- RENAME Issue
