I'm using Remo DNC 5.0 currently and am trying to use the auto repeat option while drip feeding.
I have replaced the M30 with an M00 and M01 to no avail. It gets to the end of the program the first time and then the infeed is lost.
it does however manage to send the top part of the program again and says it's waiting for CNC in the remo interface.
The machine however stops recieving the program and appears to have terminated the connection.
Any advice would be most helpful
Thank you
By: Darren Stranger
Posted on: Apr 1 2014 at 11:45:18 PM
Also it's beening feed into a Maho 432 Control
Posted on: Apr 2 2014 at 08:38:31 PM
You said it manages to feed the top part of the program and then stops and says "waiting for cnc". When remo goes back to the top and sends the first few blocks Does the cnc actually execute that top part or did it stop as soon as it hit the m30/m00/m01
Normally the machine wouldn't restart automatically. You'd be expected to put in another workpiece and hit the cycle start button on the cnc.
By: Darren Stranger
Posted on: Apr 2 2014 at 10:32:52 PM
Yes I did assume that I would have to press the cycle start again. However doing that didn't allow it to keep feeding.
It does feed in the first few lines of the start of the program again and I can see them in the control but hen it reaches the M01(optional stop), which it is now it shows me that its no longer feeding in. When the program is feeding in while you're executing it it has a display of the lines fed in and which line it is currently executing.
When it reachs the M01 it loses that lines fed in display and wont go any further.
Thank you for replying to promotly by the way
Posted on: Apr 3 2014 at 08:26:24 PM
In the DNC what flow control option is selected?
By: Darren Stranger
Posted on: Apr 3 2014 at 10:56:31 PM
XonXoff
Posted on: Apr 4 2014 at 09:41:16 AM
Change it to "XonXoff (wait xon)"
