Topic: Run Time Error 1009
By: Ken KarveyPosted on: May 9 2011 at 08:58:19 PM
I am new to your software.
I am trying to connect with a Mazak M Plus, a Fanuc OT.
Am using the same cable I have been using with my Pro Com.
I am using Windows XP.
When I hook up and it automatically shows my Port Settings.
When I run Port Scan I get the Run Time Error.
If I try hitting the recieve from the Drop down box it starts to download but never shows the proper parameters.
Any ideas?
By: GuestPosted on: May 10 2011 at 09:55:08 PM
If you know the baud rate and other settings (same as ProCom) then just set easyDn up manually via the setup button.
Save and exit setup. Click the machine icon and then click the Receive button in the top right corner of the window. The receive window appears.
Now go to the CNC and punch send out a program. If all is configured correctly then it should appear in the easyDnc receive window.
Is that what's happening?
