Topic:   Run Time Error 339
By: AbicorPosted on: Apr 29 2009 at 07:31:25 PM
I get this with the new version 4.1a
Componet MBIProc.ocx or one of its dependencies not correctly registered: a file is missing or invalid...
Please help.
By: Marcos CortezPosted on: May 3 2009 at 07:23:33 PM
I have the same problem. Every time I tried to open easyDNC I get alarm `339`. I also check on the my C drive to makesure all the files are there and they are. The MBIProc.ocx is in the same folfer as easyDnc software. The alram that I`m getting says the following: easyDnc. run-time error `339` component `MBIProc.ocx` or one of its dependencies not correctly registered: a file is misswing or invalid. I`m using window Vista everything seems to be in place. In addition I downloaded the easyDnc from the official site. Any advice? Have a great day.
By: SupportPosted on: May 5 2009 at 12:53:26 PM
There is (was) a problem in some installations on Windows Vista.
Fixed now so download the update from the easyDnc website
http://www.dncxp.com/updates.html
By: GuestPosted on: May 6 2009 at 06:53:50 PM
Yep. That fixed it.
(I was on windows vista also)
Thanks!
By: AchileasPosted on: Apr 29 2025 at 11:08:00 AM
Hello, I have the same problem. I 've used the program on this laptop (windows 10, 64bit) since 2018 without problems. Suddenly I got this message. Should I reinstall the program? I could use the same key?
By: SupportPosted on: May 6 2025 at 08:55:32 AM
If you are talking about EasyDNC version 4 (4.1 ?) then go to this page
EasyDNC v4
Here you can download 4.7
Try that and let is know
By: AchileasPosted on: May 6 2025 at 02:48:16 PM
Hello, the version 4.7a. Should I download again?
Topic:- Run Time Error 339
