We need to be able to hit send and then have Easydnc wait to send until we get to the machine control and tell the controller to start the download. Is there a setting we can change to achieve that?
Posted on: May 2 2011 at 08:43:39 PM
Look in easyDnc flow control. You see an option
xOn xOff (wait xOn)
If you enable that then easydnc will wait for you to hit the input or cycle start button on the CNC.
If you're drip feeding then we can also repeat the transmission if you go to the advanced options and enable repeat. Make sure you have version 4.7f or above from the website at www.easydnc.com
By: phase II
Posted on: May 2 2011 at 08:56:40 PM
Thanks! the xOn/xOff was off.. so that fixed that. also tried the repeat and that works awesome! thanks!
