Topic: Strippit FC120H20 with Fanuc OP inquiry
By: BenPosted on: Nov 12 2012 at 08:35:27 AM
We have a strippit FC1250H20 turret punch machine with Fanuc-OP controls. we are interested in acquiring your software but would like to confirm first if the Multipunch Strippit programs created from an old Apple Mac can be copied to a PC in our network then the PC would send the program to the Fanuc OP controls using easy DNC 4.7 or 5.0. thank you.
By: SupportPosted on: Nov 12 2012 at 10:21:49 AM
I suspect the files on the AppleMac are just standard text files. Ignore the .fc You'll probably find that the files can be copied from the Mac to the windows PC and opened on the windows PC using any standard text editor such as windows Notepad. Maybe rename the file extension to .txt to make it more convenient.
Then yes, you should be able to send to the CNC using easyDnc software. If you're stuck then email one of the files to us and we'll take a look and see if any special conversion is required.
support at easydnc.com
