Hi, is it possible to connect a Fanuc 0im over tcp/ip directly.
Posted on: Mar 21 2014 at 08:09:56 PM
remo connects to serial ports. Those serial ports can be directly attached to the computer or they can be remote ethernet ComPort device/servers which, in turn, are connected the CNC's serial port.
If your fanuc has an ethernet port then you can probably connect that to an ethernet LAN allowing you to browse the network using the cnc console. Not for DNC.
Posted on: Apr 8 2014 at 01:55:38 PM
RemoDNC can connect to IP ports such as wired or even wireless / wifi ethernet serial port devices.
In RemoDNC setup is the drop-down list of com ports. At the very top of that list is the option for IP. When you select that a box appears where you enter the ip address etc.
By: Nico
Posted on: Apr 14 2014 at 07:16:17 PM
Thanks, allready configured it..But have a problem with Dripfeeding. Another topic overhere (AWK1127)
