Topic: Trying to drip feed leadwell v40 fanuc 21m controller
By: GuestPosted on: Dec 10 2012 at 10:29:01 PM
machine will except a short program but not excepting drip feed just keeps alarming out 085 is this a setting in my parameters ? we have a trial version to see if it will work for us. or do we need to purchase the full version?
By: SupportPosted on: Dec 10 2012 at 11:25:07 PM
The trial software is fully functional so no, buying the full version will not solve your problem.
The fact that you can send smaller files suggests that most settings ate correct and your 085 alarm is most probably related to a buffer overrun.
In easydnc setup make sure you have flow control XonXoff enabled. Also try increasing Block Delay to a bigger number.
