Topic: Use EasyDnc with Sieb & Meyer equipment
By: Philou22Posted on: Oct 6 2006 at 01:52:46 PM
Hi.
I have olds machines (drillers) with Sieb & Meyer CNC.
I use their software (a old DOS version) to load program into CNC from Network, but this old software is running only with 50 Mhz CPU Max (486).
So, i would like to use EasyDnc, but i don`t know what is the good mode for this Equipment.
Do you (or somebody here) know ?
Thanks a lot.
Philippe from France.
By: SupportPosted on: Oct 6 2006 at 06:47:34 PM
Right click with your mouse on the machine Icon. A small menu appears. At the bottom of that menu you see an option "Port Scan".
Click the Portscan button and a scanning window opens.
Go to your CNC an send/punch a program.
Assuming this is successfull you will strange symbols appear on easyDnc`s display but then slowly proper readable CNC data should begin to appear as easyDnc tunes itself in to your CNC`s communications parameters. If you need you you can punch more data from the CNC without restarting the portscan.
Once the procedure is complete you can click the `Save` button to save your parameters and that`s it. You should now be able to use easyDnc to send data to your CNC.
Any problems or questions please email me
support3 at easydnc dot com
