Topic: wiring usb to 25pin
By: GuestPosted on: Jul 26 2010 at 07:18:31 PM
can anyone help need a wiring diagram for connection usb to 25pin. using easydnc and connecting to a bridgeport interact 2
By: Support,Posted on: Jul 27 2010 at 10:20:05 AM
Hello,
You can't simply wire RS232 direct to USB.
You need to buy a USB-RS232 adapter/cable. Get them at any computer shop.radioshack etc.
That's a short cable with a USB plug on one end and a 9pin serial port on the other. It also comes with a ~Cd containing the device driver software.
Once you have that you can make up cables are described on the website at
www.dncsetup.com
By: robby,Posted on: Jul 29 2010 at 07:53:13 AM
i have bought a usb to 9pin then using my 9pin to 25pin lead connecting to machine. when i connect to controller as soon as i port scan or send file to laptop my laptop freezes. i have been using dnc on an old laptop with 9pin connection so i know it did work this way. could it be the usb to 9pin as it was cheap of ebay? or could it be the wiring in the 9pin to 25pin cable?
By: Support,Posted on: Jul 29 2010 at 04:27:10 PM
Is the 9-to-25 pin the same as it was with the old laptop ?
Is it made up like the diagram at www.dncsetup.com
Download the free software from www.comdiag.com and run the diagnostics. You can run more tests if you can loop-back at the end of the cable so the diag is running through the port and then up and down the cable.
email us
support at easydnc.com
