Topic: error 086 P/S Alarm
By: JanPosted on: Jun 20 2009 at 12:58:47 AM
I'm getting this error displayed on Fanuc OT series while trying to transfer
code from machine to laptop, I'm using the function "scan port"
PLEASE HELP !!
By: PhilP Posted on: Jun 20 2009 at 01:09:23 PM
Check your cable.,
Do you have connections to pins 6, 8 and 20.
Take a look at
DNC Setup and Cable Diagrams
for proper cable diagram.
Look at the connections to pins 6, 8 and 20. Normal shop bought RS232 cables don't have those connections so your CNC will likely throw an alarm. Best thing is to make your own cable
By: Guest,Posted on: Jun 30 2010 at 05:38:54 PM
chech the spped of your machine
By: Guest,Posted on: Jun 30 2010 at 05:40:35 PM
the spedd of your computer and your machine have to be the same
By: CncMan,Posted on: Jul 1 2010 at 09:31:27 AM
The original poster said he's using "Port Scan". This is an automatic mode so the user does not need to check the speed - easyDnc should detect the speed automatically.
I agree with support - error 086 is probably caused by missing connections 6,8,20 in the cnc end of the cable. The kind of cable you get from RS doesn't have those connections - make the cable yourself.
