We get a DR signal off on the CNC machine and in easyDNC we get an ATTENTION IS CONFIGURED TO USER COM 16 BUT THE PORT IS NOT AVAILABLE. iT MAY BE IN USE BY ANOTHER dnc OR OTHER PROCESS
Odd thing it worked for a while and thru up this message
By: Bilbo
Posted on: Jan 10 2013 at 07:51:29 PM
DR signal is the cable. The CNC end of the cable needs to have pins 6,8 and 20 all linked together. See the diagrams at
The message about port not available. If you have multiple DNC windows open then maybe one of the others is using com16?
How many com ports do you have? Close easyDnc and restart it. Then without opening any DNC windows go into easydnc setup and click the "detect ports" buttons and that will show a list of available ports and whether they're free or busy.
By: Bernard
Posted on: Jan 10 2013 at 10:03:02 PM
We do have pins linked we used a gender changer Null Adapter to link. If I reboot the machine and computer it will works for a few then gives me the same error.
Posted on: Jan 11 2013 at 08:48:11 AM
As Bilbo said, How many com ports do you have? Close easyDnc and restart it. Then without opening any DNC windows go into easydnc setup and click the "detect ports" buttons and that will show a list of available ports and whether they're free or busy. What does it say.
And why com16? Are you using a multipprt serial adapter/box? Serial port server? windows terminal server? Remote desktop etc? basically what hardware is it?
Posted on: Jan 14 2013 at 07:44:47 PM
I have over 100 ports I was using a virtual port software. I am using mulitple Moxa Nport boxes that are connected to the CNC machine.
Posted on: Jan 14 2013 at 08:11:30 PM
Tell be the following 3 ports are avaiable
Com 1 - communication port
Com 3 Active Mgmt Technology
Com 5 MOs Chip PCI Serial
They are serial port server
Posted on: Jan 14 2013 at 10:38:46 PM
Might be best if you guys email.
By: Tony
Posted on: Apr 8 2013 at 11:07:55 AM
I have an error at the end of the download
Error during read the control gets the program
The control i have is G&l 8000B two machines with the idenical problems
The machine side does not no when the program /downlad is completed How cam resolve thei problem
Thank you
Posted on: Apr 10 2013 at 01:00:02 PM
Not sure what "G&I" is. But I'd say that at the end of the file the CNC is expecting some special 'end' character. In its simplest form used by most CNC's this is just a % percent symbol at the very end of the file. If your file doesn't have one try entering one before sending the file to the CNC.
Failing that you need to look through your documentation for the control. It will usually show the expected file (tape) format. When you know what special character you want you can enter the ASCII value for that character into the advanced settings of the easyDnc setup and easyDnc will insert that character automatically at the end of each upload to the CNC.
If you have the 'character' but don't know its ascii value come back here and tell us.
