Topic: fanuc 11 drip feed problem
By: SammyPosted on: Jan 28 2010 at 02:56:59 PM
i have an old mazak with the fanuc 11 controller and am trying to drip feed. i have parameters 5110, 5120, 5130 set to 3. and have the baud rate at 2400 and have tried at 9600 on controller, com port, and easyDNC software. stop bits are at 1, parity is even. select tape mode, cycle start, send the program and it starts running. it will run for approx five mins then give buffer overflow alarm. i have the block delay set as high as it will go. and have tried turning off the fifo buffer for the port. and still the problem persists. can anyone help me?
By: Support,Posted on: Jan 29 2010 at 11:28:41 AM
Please email me - I'd like to send you an update to try.
support at easydnc dot com
By: Dave, Posted on: Oct 21 2010 at 01:56:26 PM
Support - Can you e-mail me the same info? Sammy no longer works for us, and the machine is having the same problem again.
Thanks.
d dot smith dot ned at ..........
By: Support,Posted on: Oct 22 2010 at 06:01:50 PM
Dave, I sent you an email
The original post was in January - Sammy never emailed me so i didn't actually send him anything.
Did you take a look at the settings at
DNC Setup for Fanuc CNC
