Topic:   Mazatrol T1 - Mazak QT20
By: Guest Posted on: Aug 2 2012 at 10:58:20 AM
Hi Guys
Has anyone tried this software on a Mazatrol T1 (without ISO)
I just want to store and reload jobs
Also
Does anyone have the parameter decode for a T1 and cable pinouts
Michael
Melbourne Australia
By: Support Posted on: Aug 2 2012 at 05:44:24 PM
Sorry, easyDnc only works on Mazak with ISO.
The cable is the same as Mazak T2
If you really want to communicate using mazatrol protocol then try someone like Griffo Bros. (Google for "Mazak griffo Bros")
By: devidhk@Posted on: Nov 11 2012 at 06:52:53 AM
please send me parameter mazak mazatrol T1
By: Guest Posted on: Nov 11 2012 at 09:08:06 PM
As mentioned above the CNC must be capable of input/output using ISO rather than Mazatrol. I'm not sure whetherT1 is able to do that without the ISO option.
So, first check to see if your CNC has the ISO/EIA option and then look at www.dncsetup.com to see how other mazak are configured to see if any of those match your available parameters.
By: GuestPosted on: Jan 6 2017 at 10:20:37 AM
4809
By: GuestPosted on: Feb 24 2025 at 09:42:15 PM
I want mazatrol quick turn 20 universal
With T1 parameters
Topic:- Mazatrol T1 - Mazak QT20
