Home
Prices
Topic: Question on rs232 cable
By: Brian
Posted on: Dec 11 2008 at 09:30:56 PM
Will a standard DB9 to DB25 Null Modem cable work with your program to connect to a Fadal VMC 15?
Our cables are worn and I am hoping a plain old DB9 to DB25 Null Modem cable will be fine or will I need some clever pinout done?
Posted on: Dec 15 2008 at 10:38:14 AM
easyDnc doesn`t need any special cable - Our manual is just a suggestion.
If your fadal manual says something different then you can go with the fadal manual if you want. easyDnc won`t mind either way.
By: Vasudev,
Posted on: Dec 29 2010 at 11:44:21 AM
please give pin connection detail from Hinumiric 2000 to VMC 345 &STC-25
By: Guest,
Posted on: Dec 31 2010 at 11:34:06 AM
go to
DNC Setup
