I have a Bridgeport CNC with Boss 4 control. Firstly when I try to do tool length off sets as it says in the manual nothing happens.i.e. the T LED does not light up when I try to select it. Can anyont give me advice on wehther there is something wrong with the control.
I have downloaded easy DNC 4.7 (Trial Version) and have tried to load a programme on to the machine but with no success. I am not sure weather things like parity are set correctly. Easy DNC automatically scans for setting from the CNC when a programme is sent from it to the computer. However I am not certain how to do this. If anyone could give me information on the setting and how to do things on this control I would be very grateful.
Many Regards.
Jason.
doesn't show much for Boss suggesting that it should be quite easy to setup. Do you have the cable correctly wired ?
By: Jason.,
Posted on: Jan 10 2010 at 09:10:56 PM
The cable I have came with the machine. The company that I bought the machine from used EZ-CAM that runs in MS Dos 6.22. I was given this software on a floppy disk and tried loading it in modern versions of Dos and Dos 6.0 but just keeps coming up with improper version of command.com. From what I was told the machine worked fine with this software. Do I need to wire the cable differently for the easy dnc software or is the cable specific for the CNC rather than the software.
By: Guest,
Posted on: Jan 10 2010 at 09:14:00 PM
Sorry just one other thing. The cable is wired with a 9 pin plug at the PC and there is a 9 pin at the CNC. However there are only three pins ctually wired at the CNC end
By: Support,
Posted on: Jan 11 2010 at 09:05:16 PM
You will not need a special cable for easyDnc - if the cable worked with dos then it should also work with easyDnc.
