Right click the relevant CNC icon and select "Open" from the menu. This opens the Microsoft Windows file-select dialog allowing you to navigate around your computer’s file system or even your network to select the file that will be sent to the CNC.
In our example we’ll select the file O3475 and click the [Open] button to load the file into easyDnc.
Tip: You may find it easier - and quicker - to load your CNC files into easyDnc by simply dragging and dropping them from a Windows folder straight onto the machine icon.
This does not move the files - it just tells easyDnc where they are.
Selecting file to load into easyDnc transmit buffer
